Rip Of Merchants
gilenes
G'day everyone - I own a 96 wide-bodied Camry which has 200,000 behind it and suddenly my first problem struck! Rough idling, Blue Smoke and in General a very sick Motor Car. Took it to #1 Toyota dealer who promptly told me that the Motor needed a Overhaul - Cost $4,800 - second dealer said "New Motor Mate" - $10,000! Called a Mobile Mechanic - same story - overhaul motor $4,800. Not to be bluffed I systematically replaced the following - New Spark Plugs and leads, New Distributor Cover and Rotor buttons,New Coil and new air flow chamber - performance improved but still was terrible. Mobile Mechanic #2 advised that the rings and/or valves needed replacing - $6,000. Following a discussion with a friend of a friend I had the car completely diagnosed (should have done this first), and it indicated a problem with EU - this resulted in a purchase of an exchange ECU UNIT which is located under the dash on the passenger side - cost $275!!! I fitted the new unit myself and the car is totally different to drive - Superior Power, Smoother Gear Changes and fuel economy has changed dramatically and is being monitored, As I said there are some sharks out there as well as persons who don't know what they are talking about!
Hmmm where about is this merchant located. I couldn't agree more regarding to there's sharks out there and people, :/ a friend of mine is like that. Thou I get your point mate. Beside is your car all fix now? Pics? :)
Welcome to the club :D Good to see you didn't settle for those extravagant repair costs and did some investigating. Thankfully it didn't blow out in cost and was something nice and simple. Sometimes I wonder how good some mechanics are and how thorough there knowledge is. I suppose it's with everything, you'll always find there are good ones and bad ones
even if you needed a new engine, those prices are absolutely spastic. a 5SFE or 3VZFE can be has for less than 300$ these days...
+1 To that lol u can buy the same car with that amount lol maybe even two
      Wobble at the front
    2. 7
      Brake issues
    3. 10
      Best Oil for 2014 Lancruiser GXL 200 series TT V8 Diesel
    4. 25
      RADIO CODES "HELP"
    5. 17
      Wobble at the front
    6. 11
      rear wheel arch hole covers (3rd row seats removed)
      2013 Kluger grande Bluetooth music issues
      2010 MANUAL Prado with high speed acceleration hickup
    9. 10
    10. 1
