02 Camry Sportivo (MCV36R) Stereo
warpye
I want to replace the stock double din headunit in my Camry with one that I can connect my MP3 player to, bluetooth/aux in, I knwo how to remove the existing stereo, but I need to get the double to single din adapter and wiring harness, but bugger me if I can find them.
Can anyone point me in the right direction, thanks.
The 2to1 DIN adapters can be found in most car audio places and as for the Wiring harness; when I hooked up my headunit I just used the existing wiring. Give me a day or 2 and I can get you pictures of the wiring and what they connect to on the headunit.
Keep in mind however, I run my speakers off amplifiers so I don't know which wires connect to the speakers.
For the harness, if you dont want to cut your stock harness, then just go to supercheap/car audio store/autobarn/(insert car shop) and but this http://www.aerpro.com.au/list.php?pcode=CHTO2A&cat_name=HARNESSES+++++++++++++++++++++&cat_no=10&product_name=CONTROL+HARNESS+A+FOR+TOYOTA&cat_sno= . If your head unit is a brand specific plug then cut the harness and join all the wires up before fitting into the car, so when you are actually installing it all you need to do is plug in both ends.
Have you considered a double din replacement that has all the features your after?
My 2003 Sportivo had the standard 6 CD unit and I just replaced it with an Ebay unit
that has bluetooth, touch screen high res, AU GPS, MP3, DVD, Ipod in and SD car,USB in, etc and reversing camera input for about $260.
The unit had its own Toyota Camry wiring adaptor so it was plug and play, perfect fit
into the existing brackets and no gap when the dash went in.
Easily the fastest install ever done, maybe 10 mins?
The units sell for about $350 on Ebay, I bid on one
and it only went to $220 plus shipping, pretty happy with it.
      New Member
    3. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    6. 199
      Advice Please
      A Greenskin
    9. 1
      Car Detailing Recommendations
