Seatbelt warning light and buzzer
Azza313
Hi there all,
My daughter just bought a 2006 3 Door Yaris YRX.
We have just found that the Passenger Seat - Seatbelt Warning Light and Buzzer isn't working. Driver's side is fine.
Does anyone have an idea how to diagnose and hopefully fix this problem?
Thanks heaps,
Mike
Look underneath the seat and see if the wiring connector is plugged in to start with...
If not, plug it in :)
If it is, then start checking for power and earth, if it's got both the wire inside the seat base could have come loose or the sensor may need to be replaced...
Thanks heaps,
Cheers,
Mike
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
      Rav4 smart key keyless entry
    9. 13
      Starter motor issues
