as the topic says, as the wheel nuts the same as i am going to put sportivo rims on an ascent which had the steel rims with the plastic hub caps. can they be interswapped????
Also how much are the nuts each???
cheers
Posted (edited)
ASCENT steel wheels need STEEL nuts
SPORTIVO COROLLA needs shank nuts only from toyota
you could try aftermarket but most likely the size is a couple of mm off as toyota have designed the nut differently.
if you order make sure you request for the corolla or they might give you the sportivo camry and these nuts have a shorter head
price about $6 each
Edited by kcorro
Hey arcxis
I have the sportivo rims on my rolla ascent. :D
Yeh as kcorro said u need to get the corolla sportivo nuts
i got mine for 9.60$ each
Northy had an Ascent and now he's got a Stivo and he's still the same nut :lol:
Yeah - but does he still have the SAME nuts???
last time i checked azza, btw does your missus still have yours :P
I still got mine.....She left them behind when she went to Sydney this week....
She just took the EFTPOS cards....
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
