Hi
Has anyone ever performed a drum to disc conversion on an echo?
I've done a Camry drum to disc. Toyota had a habit of using the same hubs if a model came with variatons of drum and disc, and disc all around. All you need is the parts from the all round disc version if there was one made and possibly the proportioning valve.
The Jap spec Yaris RS had rear disks.
Did a rear disk convo on my ae86 and used the drum proportioning valve, rear disks kept locking up even on light braking.. chucked in the disk prop valve and it fixed the rear locking first issue.
Hi
Been done plenty overseas. No one in Australia has done it though to my knowledge.
Why do you want rear discs? looks?
Hi
Got a link, i want to do this to the vitz.
and yes, only for looks.
