HELP RIMS
t0_ny00
hey i need help with my camry, my amtes selling Drift R with rubber and he first was ognna buy it from him but he had mix up with his offset, therefore he must sell. i was wodnering would 17" Drift R rims with offet of 21 and PCD 5*114.3, would fit on my camry, the camry is a 2001 camry, the long salon one.
thanks
tony
hey
the PCD size is right, but im not too sure what the offset means :(
i heard that if you want to get 17" Rims get the offset thats 45mm+
im not a huge fan of the wheels, im as lost as you are when it comes to wheels. all i know is that the camry has 114.3PC and offseet of 45mm+ is perfect. <_< hope this all make any sense :D
  • 6 months later...
it depends on width not diameter of the wheel.
7" ~+48mm
7.5" ~+45mm
8" ~+42mm
8.5" ~+40mm
im pretty sure those are close enough for a gen4/5 from previous readings. just remember you still need to size correct tyres to avoid guard and strut rubbing.
if you have drumb brake rears you will want slighly less offset on the rears for 7" and 7.5" wheels if in smaller diameters to clear the brakes.
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
