Whiteline rear sway bar and strut brace
ZEEROLLA
Hi Guys,
I was looking at purchasing the rear sway bar late last year after seeing one come up on ebay for about $100, so i thought i would do a bit of research, and emailed whiteline directly....
This is a copy of an email conversation i had with one of the guys from whiteline about the rear swaybar (if you could call it that)....
Hi Mark,
Thanks for your e-mail and sorry about my delayed reply.
The rear swaybar is inside the rear beam axle. I have attached a picture for you.
Our notes show that the factory front swaybar is 22mm. We supply 24mm.
I hope that this is OK.
Regards
Bob
www.whiteline.com.au
>-----Original Message-----
>From: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
>Sent: Friday, 31 October 2003 1:28 PM
>To: Support
>Cc: xxxxxxxxxxxxxxxxxxxxxxxxxx
>Subject: BTR77 for zze122 corolla
>Hi,
>I was just wondering if you could gie me some more information
>on your rear sway bar for the latest model corolla. I was
>wondering if the Bar comes with everything required to fit it,
>correct me if i'm wrong but from the look i have had under my
>car i can not see a rear sway bar and so i am wondering if
>yours comes with all the mounts linkages etc to correctly fit it....
>Also i was curious as to why the front sway bar for the same
>car BTF72/BTF72Z is the same diameter as the factory bar
>If you could please reply to this email address as well as my
>home account xxxxxxxxxxxxxxxxxx it would be much appreaciated.
>Thanks...
>Mark
After seeing this and having a look under my car i decided not to purchase the rear bar...
Edit: resized picture to make it more friendly for people on dialup
all the other factory bar's on the recent rolla's I've changed have been hollow. But when MAP81's factory front bar was measured with some vernier calipers at Motorama Toyota, it measured 24mm.
That rear "swaybar" is clearly a ripoff, cheaper to remove your stock one and paint it blue/silver... it will do exactly the same thing and only cost you $12 in paint ;)
Hmm, or maybe i should just spend money on lowered springs instead! I will call them up and clarify this with them. If they can guarantee the rear sway bar works then i will go ahead. Otherwise i might just save the money and go for the springs <_< I will still go with the strut brace and urethane bushes though :lol:
I spoke to man at Rev. Racegear today and he said that if Whiteline manufactured the rear bar for the Corolla, it must have been proven to work :blink: This is the same bar used for all Corollas with torsion beam rear suspension. He says they make adjustable bars for the front and rear, and even if it was only an upgrade of 1mm, it would still make a significant difference in rigidity. But i have put the swaybar and urethane bushes on hold for now and will probably get the Strut-Bar & K & N filter first. Have to find out if these bars would void warranty!
Imek, as to the urethane bushes, i ordered them from the same store. They are manufactured by Whiteline. Don't know the part no. though. But you can probably find them at the Whiteline Website. :lol:
