will it fit so it can meet requirements !!
bigVAN
hey guys ,
just purchased a set of 20inch mag wheels .
the tyres on them are 225-35-20 , and the loading limit is 600kg . (these wheels came off a '08 camry)
my camry's minimum requiremnt is 690kg .
so my question is will i have to purchase tyres with a greater width ? such as 245-35-20 ? and will that fit ?
You have to look up for load ratings instead of the width if you're concern about the load requirements.
http://www.tyrepower.com.au/tyre_load.aspx
Dpending on your width of your 20s and your offset, it may scrub. It also dpends on whether you're on coils / springs. Althought that's another issue, the general answer to your question is: yes it will fit.
Hi Van,
How wide are the rims?
20x8.5 i think !! : / , current tyres on them are 225-35-20 , and the loading limit is 600kg (90W)
the placard on the car says i need 690kg (95W) or greater . so im looking at 245-30-20 ? which is recommended i hear ?
dead stock suspension lol . going springs within several weeks :)
20x8.5 is totally fine.. Why would you wanna go 30 profiles instead of 35? What offset what are you on?
edit: doesnt matter, just realized ur on stock. So won't have any scrubs problem.
      ZRE182 Nudge bar
      2016 Hilux SR5 Coolant Issues
    7. 2
      What to say!
    10. 4
