2003 Sportivo
Give us a photo of what you've got, number each of the hoses and each of the nipple/mounting points for the hoses and I'm sure myself or someone else can easily map them out for you.
There is one small hose that connects just after the throttle body butterfly their are two bigger hoses also connecting to the throttle body at the same point. This little hose has a directional flow valve in it allowing only air to flow towards the throttle body (/intake manifold).
Then it goes into a t-joint by the AirBox. One of the other two points on the t-joint goes to a vacuums cavity on the back side of the air box.
The final point on the t-joint goes to the vacuum solenoid valve, that then goes to and controls flap on the air box that opens in lift.
Which hose goes to the round diapham looking connection ?
I assume you mean the thing controls the airbox flap???
The hose coming out of the electronic valve that is opened in lift by the computer goes into the
this allows the vacuum to open the flap in lift.
      Head Unit with Apple CarPlay
      Any RA 60 owners?
      Bluetooth stopped working
    6. 3
    7. 2
