hey guys i have a 2002 3.0L hilux and the motor shakes violently when the A/C is on when on idle and pulling up at the lights ... only on idle and when the fuel is low it does it again it like the gear knob will leave bruises on your knees its that bad , it doesnt seems to sound like its down a lung it just shakes ive replace the fuel filter and put some chemtech injector clean in the fuel but seems to still do it
has any one had this problem ?
could it be that the fuel tank has some crap in it ?
maybe an injector ?
praying its not the injector pump :blink:
Engine / gearbox mount?
Idle speed too low/bad fuel filter? AC should force idle to at least 900rpm, possibly more-see manual for precise behaviour. Do not often run low on fuel-it sucks up all the crud from the bottom of the tank into the system, and it may invite air bubbles into fuel lines-All cause bad running or damage.
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
