2001 Estima Aeras factory cd player Help needed
Zui
Hi all,
I recently purchased the above vehicle and i require the user manual for this vehicle as it is all in japanese. is there any way that i can change the settings to english ? Do i have to replace the system?
Regards
Zui
If you could find a user manual it would be in Japanese as well and there's no way to change the settings in the unit. Don't bother wasting your time with it and just put in an aftermarket one.
Pioneer do a nice touch screen Double DIN DVD unit with bluetooth, reverse camera input, USB, Ipod/Iphone control and can be upgraded to run the pioneer GPS. Unit without GPS retails at about $800 but I've seen factory seconds and as new units go for $4-500.
g day andrew and welcome to the forum, i have a 2000 2001 estima handbook in english, i cant download the file it is to big , might be because im not a paid member. will see what i can do cheers
Thanks legend. I appreciate anything that you can do for me.
  • 3 months later...
Hey Guys,
Just bought the same car for my wife.
Any luck on the user manual for the stereo?
Also does anyone know if the stereo removal is an easy job???
I wanted to install a FM Converter so she can listen to the radio.
- Dennis
Hey Guys,
- Dennis
Removal is very easy. Use a flat blade (I used a butter knife) to gently prise of the facia around the stereo unit. Just slip the blade in to small gap between the facia plate and the dash and levers up - do not force it if it won't come out. There are 6 clips holding it.
Now you can remove the plug for the Hazard lights and remove the facia entirely. Next remove the 4 screws holding the unit in. Remove the aerial from the back and plug it into your band expander. Plug in your aerial cord from the band expander to your unit (now it is inline). You may need to find a power wire for the expander too.
  • 7 months later...
Hi Legend
folder is 13.8 mb it exceeds the limit im allowed to post as im not a club member. i could email it to you if you like
Do you still have this file available ?
I am expecting delivery of our Estima 2000 in the next few weeks and have been searching for an English Handbook.
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
