speaking of wheels I'm thinking of these in 18's thought's?
http://www.work-wheels.net/files/files_instal/0.59342200%201382580146_1688.jpg
http://www.work-wheels.net/files/files_instal/0.16360400%201382580156_1690.jpg
http://www.work-wheels.net/files/files_instal/0.47529100%201382580151_1689.jpg
Also anyone know the maximum offset I could go on fronts and rear? keeping in mind I don't have stock ride height, or would it be best to just hit up a shop and check to see what clearances i could pull off?
Off set and width go hand in hand... Need to know sizes before offset... Anyway a little poke never killed anyone
So could I run say for example 18x8.5 +30? in fronts and rear? Or what's the widest width and offset I could go in the rear?
well i have my rukus and already picked out rims for it. Silly question would 18.8 fit fine without rolling the fenders? i already have lowering springs here which should be in a few days
Depends on the offset of the wheel.... But being 18x8 I would assume they are off the shelf wheels and will run around the +40 mark so you will be fine
thanks for the reply, I'm buying these http://shop.cartel-aus.com/Inovit-Wheels-Inovit.htm was just hoping they'd be fine. before i bought them.
keen to see what the look like on the car. make sure you take pics and put them here:)
my only problem is that +40 seems a bit weak
can i ask what you mean seems a bit weak?
cheers.
heya. it means the gap between the edge of the rim and the spoke.
http://www.willtheyfit.com/
try this site for more info.
for example +20 will have 'more dish' than a +40
hope that makes sense
yeah they will definitly fit and how "weak" they fit refers to the offset...
a 0 offset has the hub part of the wheel in the centre of the wheel...
+ 40 offset is 40mm past the centre of the wheel
-12 offset is 12mm further in the wheel
generaly speaking the higher the number the more the wheels will tuck into the guards..
lower will get the wheels sticking out for that poked look...
    2. 9
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    7. 18
    8. 5
      Tow bar
