removal of eye lids
hey guys might diy the black housing headlights,
the thing is that the eye lids look super glued or something to the headlights ?
question is should i just leave it and try remove headlights or take them off all together and is it possible?
thanks guys
super glue? your fu#ked...
double sided tape, use heat gun and slowly peel away, be careful if ur eyelids are made out of plastic ull be safe. if they are fibre glass they WILL snap.
^ as above, i used a stanley knife, but only because the tape was a little on the thick side, otherwise you really risk scratching your headlights
haha nah i didnt superglue it , the previous owner did -.- .
the eyelids are beginning to crack and paints coming as well but seems abit hard to remove lol
haha might just leave them on too much effort removing them.
off topic some guys selling a cooling panel on firesport, he says that it will fit both preface and facelift corollas?
i have a feeling that it will only fit one or the other ?
anyone able to clear this up for me
I've only got the one on. Left one ;)
is that why ur dp is only the left side of the car? LAWL :D
Lol nah man, when I did my motor my work shirt got caught on the end of it, it pulled it, I tried to re-double side tape the end but kept sticking out so removed it, havnt been bothered putting it back on, besides, character. ;)
Edited by 123R-Prozak
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
      Upgrade from 2012 to 2023
    9. 3
      Towbars
    10. 5
