Posted (edited)
I have a 2001 LWB Hi Ace model RZH113R-RBPREQ and have a oil leak. It appears to be in the sump gasket on the drivers side right at the front. The oil does not appear to be coming from above the sump gasket. It is leaking a lot and can not be driven or I will lose all the oil.
Guess there is no easy method of putting fiber glass or something along the gasket. I guess it is under pressure and will always force the oil out.
The oil pan will only drop down a small amount so is it possible to easily replace the sump gasket .
Any advice would be appreciated.
Edited by Firepower
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
