POD Filter And Cold Air Intakes A Myth???
06 Sportivo Bloke
Already been posted
http://au.toyotaowne...882#entry492882
You can't put a blanket "busted" down on something which varies from car-to-car, dyno-to-dyno and day-to-day. If you have a car with a really bad intake, switching to a pod filter and CAI can really make some improvements. If you already have a good air feed and nice un-restrictive factory intake then switching will probably have next-to-no effect.
And CAIs can't really be judged on a rolling road/chassis dyno, as the air flow and engine-bay temperatures are not indicative of real world situations (note most dynos will open the bonnet for instance, which reduces engine-bay temps and reduces the difference between a normal intake and a cold one. Also, cars on a dyno can get up to 180km/h+ (the Soarer for instance hits ~190 in 4th), so unless the fan can generate 180km/h winds, you're not going to accurately replicate the airflow over the car and thus any high/low pressure areas and ram-effects (also note that the fan will be drawing dyno-cell air which usually be warmer than ambient outside air.
Sure, on a lot of cars, especially "low"-powered N/A cars like a lot of ours would be classed as, a pod filter and CAI may gain a couple of kws here and there (maybe a few more on the butt dyno), but there is no denying that a properly designed, built and located cold air intake (especially if it helps to remove factory restrictions) can significantly improve the performance of a more powerful car, especially turbos as they luuuuurve cold air.
      Toyota Landcruiser problems
    3. 13
      300 series turbo issues
    4. 55
      Stout Owners
    5. 13
    6. 8
    7. 55
      Stout Owners
    8. 2
      New Member
