Wanting to install a pair of 6x9 speakers in the back of the cab but I have no idea which wires are which if anyone can help would be great and also is it worth putting an amp in as well
I'm not sure if the xtra cabs have the wiring there, you might need to run them from the back of the headunit
Amp is well worth it but only if using aftermarket speakers
I've run wires to behind the head unit was unsure of which wires they are for the head unit
And I already had a pair of Rockford fosgate speaker in my old ute that i took out to put in the hilux
Ok well below is the wiring diagram for a Toyota Vigo, which is essentially the exact same as our Hilux even down to the wiring. Hope it helps.
post-13080-0-52422200-1343650704_thumb.j
Ok thanks mate I'll have a look and see how we go
      Remote start
    2. 1
    3. 0
    4. 9
      Android auto
    5. 9
      Android auto
    6. 1
      Turboed Corolla Overbuilt?
    7. 3
    8. 3
