I don't have an oil pressure gauge, and want to know roughly what hot idle oil pressure I can expect from a good 245000km motor, and roughly by what rpm full oil pressure is regained on new cartridges and oil?
NB I WAS going to use the oil light switch hole for a feed, but realizing the rear bearing feed would be more seriously affected, and believing the supply weaker than ideal, I will fit a sandwich plate.
Just curious, does the vacuum pump draw oil from sump or mains oil pressure feed?
I have a new, unused, spare Indian-made SCC20 cleanable centrifugal filter if anyone is interested. 6mm supply, 2x1mm discharge holes @ r=25mm-55psi max, with 1.5mm dia regulation hole. Flow is abt 20gal/hr + regulation discharge. Prob Imp. w bronze bushes. Suit sumps upto 20L or biodiesel. <1 micron filtration claimed.
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
