JJCRU23R - NISSAN CUBE3
JJCRU23R
The expanding foam in the cardboard box will be a mold for the fiberglass box I need to build for the subwoofer. Doing this means I can fiberglass without having to stink up the car with fumes!
6" Stock speakers OUT.
06054629-FAE2-410F-B490-2D14CF52E36E-428
6.5" Rockford Fosgate PUNCH split speakers IN!
7D08978F-BE5A-4D21-A017-AE49434CF0CF-428
C4C1B73E-95B6-4FDA-9D8F-19A6A35FA40C-260
After carefully positioning the drivers side tweeters, I lined up the two panels together and poked a protractor through the holes to make sure that the tweeters are symmetrial.
1B9E3331-AB21-4035-B85C-189092E4335D-260
  • 5 months later...
Fiberglass layer 1 cast. Needed cutting in 2 to remove it safely from the mold. Wasnt worried since there were plenty more layers to go inside.
04FE85C6-4B18-4FA1-9D67-0CD2AA41BDAD-104
Trial fit
78551ED6-7F7C-4601-97BD-BC1DDC2AD549-651
AC4242BF-B099-4569-8083-8DC413497AE3-651
Minimal gap in in the back of the cavity
E82416F7-DB7F-47BB-955A-145362CEC813-651
FA4A5931-4F94-4ACA-9503-431331F986D5-651
Permenantly fixed to the door..
0B1A6D19-9360-4F61-ABBE-AA36EE437223-833
C73DB85C-7806-4CCD-BD5E-5EB0944D606F-833
The theory is more curves, the stronger the fiberglass gets. The flat areas of fiberglass are generally the weakest.. So to remedy that.. add curves!
FAA1E9BD-6334-4E9D-A355-AFBC4A99D287-833
Part of the front panel..
57D86D55-1D2E-45DA-8AA5-5746E243A5CC-159
Actually that pic above was a "frame" which the actual front panel will lay on top of.
BF1727A2-2313-4CBE-B543-4126B5E26708-159
Initially, not happy with the angle against the 3rd row seats.
BB1DF2E2-2C1F-4178-BC98-3746EE8D0A36-159
B3962C3E-AA58-4C16-A6AA-B780821A4E17-159
More parallel!
7AB1BB76-2B48-4B52-905E-AC059AEEFB5C-178
Sub stored in floor behind drivers seat.
0135892C-4328-4502-BCDE-88C42A8ABF03-270
1832D13B-73DE-4304-9EED-6CCA550D3705-270
Cut the foam box inside the floor to make room for the amp plus it wont move anyore. Wiring threaded through the floors and speaker wire to the sub through the door gasket..
56E1FF40-022D-4A06-BFAB-269C8A4DDB5F-270
Vented floor panel for the sub
2CF68104-015E-43A2-9329-99561155FAE4-153
Delcate 3 layer process before carpetting.. all made from leftover MDF and black material is leftovers from my original sub box from my Corolla sub box! $0!!
B56164D9-E4A4-4958-A458-C3DE2E380034-153
New vs old
330B777A-54C0-45D1-AAA4-4D91D2C1A141-153
I should put a PC fan in there but not bothered atm.
649F9B16-0FAC-4A5B-9F5B-9DA942677140-153
Thicker than OEM but whos going to notice?
2E9725AC-B880-4EF6-80EB-275B970A8D04-153
BECAUSE.. FILIPINO :P
That is as far as its gone so far.. but I am expecting a few more things in the mail..
The cluster is VERY basic in the Cube.. need more info!
The sub wasnt functioning as well as expected, but I improved the situation by adding more resin behind the front panel.. sounds better. I have my inlaws living with us for the next few months so we need to keep this car and all 3 rows of seats on the road every day which means no time for modding the cover for the sub box.. Point is it works.. no real rush to make it look pretty at this point.
Just hit 90k on the Cube.. has been fun and functional thus far :) $35-$40 / tank... its a whole lot of fun.. not fast but the point is getting to where we need to go and enjoying the ride :)
Forgot I bought a grill for the Kicker.. cant find pics of it just yet!?!
Long story short.. everything I could have transplanted from my Corolla.. is now in the Cube3 :)
Kids keep entertained with the DVDs.. I get my doof doof back and there are still a few missing peices here and there that I need to buy before the Cube3 is complete again.
For some reason the 3rd row headrests are missing (Expensive). Also need to order one or 2 bits of the roof racks (Cheap and local)..
Budget is tight so slow and steady she goes.
Thats pretty much all for now guys... happy modding!
Hey jeffy, it is the same exact sub as before, just made a new box for it! I kept the original box for a couple years after I sold the corolla, but realized I can't even sell it- there's no other 8" kickers on sale in Australia to begin with. I got mine through my cousin in the US.
Testing the panel.
Quite flimsy but keeps in place with the shelf still behind it. May have to modify it (hack it to peices) to keep the panel in place and make room for what will eventually fill those holes.
Gauges and panel together... The panel is made of really thin and flexible acrylic.. cannot support the weight of the gauges! They flexed under the pressure from the brackets! 1/10 for rigidity.. I only gave it a 1 because it didnt break.
Loosely attached from behind to the panel.
Instructions found in each packet..
Lights off..
Lights on.. (sorry for the camera shake)
Positive and Negative/ground cables connected to elcheapo (freebee) jump starter!
Will need a kill switch and some adaptors to fit the temperature sensor in the radiator and I will need to splice into a sensor wire or two.
Thats all for now.. wont install until i have all the parts together.
