Posted (edited)
Hi bro, sorry for late, I was busy. Here they are:
The connector from my car
And I got this connector from my friend
Then I connected it to my car, just matched the wired colors. If your car's wire is difference color, just follow the order in the pic above
For the camera signal (pin 5), it is used to turn HU to reverse screen when reversing, you will see the wire's color matched with it from the 141 harness, then connect it. DONE.
Very easy, the hard thing is how to get the connector.
Read this to get more camera signal information
1: Parking brake
3: Speed sensor input
5: Reverse input
3 and 4 no wire.
These pictures are not from my car, you can read them here:
http://www.supraforums.com/forum/showthread.php?391532-Toyota-Radio-Information
Edited by nhp
  • 3 months later...
Hi everyone, i need help bad, i purchased a 2013 gxl rav 4 touch screen head unit in australia and installed it into my 2006 rav 4. Only the female 20 pin did not fit into the 16 male pins on the 2013 head unit but that doesnt matter as its only for the SWC. Everything works except there is no sound what so ever. I had to purchase an antenna adapter which works fine except theres a blue wire which i dont know where to plug in and think this might be the key.
I purchased the OEM head unit from ebay brand new. 2013 Genuine Original Toyota 6 1 Display Bluetooth MP3 Text MSG Function USB | eBay
I just cant figure why there is no sound, please help.
post-34312-0-06212700-1385720683_thumb.j
post-34312-0-32163600-1385720686_thumb.j
post-34312-0-18718400-1385720688_thumb.j
post-34312-0-05301200-1385720730_thumb.j
PZQ60-00121 steering controls plug with speed sensor
PZQ60-00161 antenna patch with the speakers
You said earlier in this thread that you installed an aftermarket camera, how is that possible if you dont have the rca adapter to plug into the 4 pin connection in the head unit? could you possibly run through the steps in how to install aftermarket camera to oem head unit ? thanks
Posted (edited)
I bought my headunit for 320 bucks at JB HI FI
I dont trust any other brand than pioneer, they have the best connectivity (mine came with DAB+ and hands free along with bluetooth music, DVD player, the option for navigation and more) In my personal opinion, pioneer absolutely craps all over factory headunits. They are easy as to install and everything just kind of works at the end of the day.
edit: www.pioneer.com.au
Also i cant see why youd bother with a reversing camera, if you know your car well enough you should have no trouble (:
Edited by doobey123
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
