gen4 mirrors
TiiCee
the gen4 mirrors arent as great, they dont give good vision at all , so i want to change them and i have been looking around for bigger external mirrors but with no luck at all , anyone know if they make any bigger external mirrors for the gen4 ? and where to buy ?
Are you worrying about blind spot? I stick round shape blind spot mirror on passenger side (external) mirror and problem sloved.
Edited by thSydney
Try looking at some Aurion side mirrors, not sure how would it fit for a gen 4, but a member here has a gen5 with them and only had to drill 1 hole for them to fit
For the gen 4 Camry, there are a factory wide angle mirror option for L/H front door mirror.
Can't remember how much i got it for, but it was cheap from Toyota.
I then use a "Broadway" rear view mirror to mount on existing rear view mirror for my blind spot.
Hope this helps.
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
