LN106 and LN107 differences
jackalwest
Hey guys,
Just bought me a 1994 2.8l TD Dual Cab 4x4 Hilux and having trouble trying to identify the type.
From my understanding the ln107 means dual cab and the ln106 is single cab?
Is this correct? Or is there something I am missing?
Regards
Jordan
P.S. Car picture uploaded
post-32572-0-20625200-1367298544_thumb.j
Mine is an LN106 dual cab.
Numbers change based on engine/trans combination I'd assume seeing there is diesel and petrol variants. Not sure if the SR5 has a different code either.
YES you are correct 107 is Dual Cab & 106 Single,
with my series GGN15R donates 2wd &
GGN25R donates 4wd, cheers mate hope this BELOW helps ya!
Modifications produced from 1994 (august)
Choose modification: Spec.
Modification Body type Drive Trans Fuel Displacement, cc Engine model Frame Price
1. Double cab SSR-X (wide body) EGR equipped car Pickup 4WD MT Diesel 2779 3L KB-LN109-PRMQS(N) $18300
2. Double cab SSR-X (wide body) Pickup 4WD MT Diesel 2779 3L KB-LN109-PRMQS $17900
3. Double cab SSR-X EGRequipped car Pickup 4WD MT Diesel 2779 3L KB-LN107-PRMGS(E) $17300
4. Double cab SSR-X Pickup 4WD MT Diesel 2779 3L KB-LN107-PRMGS(X) $17000
5. Double cab SSR EGR equipped car Pickup 4WD MT Diesel 2779 3L KB-LN107-PRMGS(N) $16100
6. Double cab SSR-X Pickup 4WD MT Gasoline 1998 3YY-E GA- YN107-PRMGE(X) $15800
7. Double cab SSR Pickup 4WD MT Diesel 2779 3L KB-LN107-PRMGS $15800
8. Double cab SR EGR equipped car Pickup 4WD MT Diesel 2779 3L KB-LN107-PRMSS(N) $15400
9. Double cab SR Pickup 4WD MT Diesel 2779 3L KB-LN107-PRMSS $15000
10. Double cab SSR Pickup 4WD MT Gasoline 1998 3YY-E GA- YN107-PRMGE $14600
11. Single cab SR EGR equipped car Pickup 4WD MT Diesel 2779 3L KB-LN106-TRMSS(N) $13800
12. Single cab SR Pickup 4WD MT Diesel 2779 3L KB-LN106-TRMSS $13500
13. Single cab DLX EGR equipped car Pickup 4WD MT Diesel 2779 3L KB-LN106-TRMDS(N) $13100
14. Single cab DLX Pickup 4WD MT Diesel 2779 3L KB-LN106-TRMDS $12800
Edited by CONROD
  • 5 years later...
Major necro, but this was on the first page of google searches.  I'm here to correct the record.
LN106 is a live axle in either single or dual cab.
LN107 is an IFS in either single or dual cab.
LN110/111 & RN110 are extra cab versions of an LN107 in diesel & petrol respectively.  IFS only. (110 is outside Aus and 111 inside)  UK has LN110 so you can still have RH drive, everywhere else is LHD.
KZN130 & VZN130 are the Surf versions of a LN107 in diesel & petrol respectively.  IFS only.  Designations in the name indicate trim levels...SSR, SSR LTD, SSR-V & SSR-X to SSR-G.  From left to right in order of nice stuff to strip out for your own project.
Don't quote me on this but I think 4-Runners are the Belmonts of Surfs.  2 door & 4 door (up to '93) and only 4 door after that.
Front quarters, bonnet...basically from the drivers seat forward they all share parts.
All surf parts are a straight bolt in.  Seats, dash, interior lights, brakes, gearboxes, transfers, diffs (including centres into housings), axles.
IFS bullbars don't fit SAS front ends, and vice versa.  Unless you like die grinders and egged out holes.
If you cut the front end off you'd never be able to tell what it was off of.  Except for trim levels and IFS or SAS.
Best brakes, trans, transfer & diffs are off a 3.0l V6 Petrol Surf
For the years and models refer to link below if you're going upgrades parts shopping.
http://www.hiluxsurf.eu/faq_general.htm#tech2
Be careful with surf transfers there's a bunch of different options electronic/chain, electronic/gears, manual gears, and I think but might be wrong electronic/gears.
Edited by Internet Retard
  • 2 years later...
On 4/30/2013 at 10:39 AM, jackalwest said:
Hey guys,
Regards
Jordan
LN 106 and 107 are probably the most popular of hilux models here in Sri Lanka. Both models come as dual cabs or single cabs, the main differences are that the 106's are only on leaf springs whereas the 107 has independent front suspension. 106 may be slightly ahead of 107 when it comes to off roading due to this, though 107 is a much more comfortable drive. 107 comes with automatic front wheel hubs.
107 also comes with more options such as sun roof, sports bar, etc.
On 2/13/2021 at 12:49 AM, Thissa said:
So I have a 1997 Dual Cab, SRS Plate says LN106, HOWEVER IFS I'm confused.  Anyone clarify please
      Starter motor issues
    4. 3
    5. 3
    6. 3
      Adding more spotlights
      GR sport tailgate seal
      Fuel light vs remaining range
