Hey guys,
For those of you with an Apexi Power FC are you running it as a stand alone ECU or as a piggy back?
After talking to someone the other day i was told you can run them as a standalone and everything works fine but from my knowledge most people run them as a piggyback.
Just curious as to what everyone has done/ the reasons behind piggybacking if it can work as a standalone?
Sam
Most go standalone (depending on model)
Some people piggy back them but theres more room for tweaking as a standalone unit as the stock ecu has some parameters that cant be changed
The PowerFC doesn't talk to all the systems in the Corolla correctly plugged straight in, as the Celica has a different method of communication with the various systems. Whether it is piggy backed or plugged straight in doesn't effect it's ability. Don't confuse a piggy back ECU with a piggy backed ECU. It will work plugged straight in, but you won't have a couple of things, the tempoerature gauge in the cluster won't work, if you re-wire it to work, then the PFC won't have a temperature signal, so take your pick as to which one gets it. You can add another temperature sensor like a conversion harness does and get both though. The radiator fan won't work without some re-wiring. The idle electrical load won't work either without the conversion harness. This can be solved by having a 1000-1200rpm idle, but you might tire of this quickly.
Conversion harness it is. Is boomslang the only place to get them from these days unless someone is selling it second hand?
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
