squeaking from engine bay
ok lets keep this simple.
got clutch changed 2000kms ago. started squeaking/chirping after 2000kms. comes from engine bay when the clutch is fully released or in gear. louder in gear and deceleration. went back to transmission shop and they said that the extended push rod is pushing out the clutch further when its released therefore making the noise. when the clutch wears in more, the noise will go. he did spray a bit of crc or wd40 equivalent on the OUTSIDE where the push rod and fork meet. no good either.
not convinced about what he said.
then quick search on forums netted this:
If u hear a squeak at idle ? Foot off the clutch?
Go
into your engine bay and use your hand and light put pressure on the
clutch fork and see if the squeak goes away.. I had this, my balljoint
the clutch fork pivots on wasn't lubed..
Just a suggestion
Also yeh sometimes 3rds notchy maybe oneday I might try new cables
Also nah not hard few split pins and stuff
should i wait until a while and if the noise comes back to back to them? they are so bloody far and i don't want to take off the transmission again just to spend 5 mins to check and lube the bloody thing and put it back together. -_- or is it something else? it surely cant be the thrust bearing as they would have put the new one in when they put in the new clutch.
just say the ball joints arent lubed properly... would driving around a short while require me to change the fork as the wearing on the fork is accelerated?
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
