CIA for 05 camry sportivo 4cyl
14
Hi from Wagga
Engine oil dipstick reading
Hi guys, Probably a silly question... I'm having trouble reading my engine oil dipstick on my Toyota Hilux 2010 3.0 Turbo Diesel. I have warmed up the engine, turned off for ~10 minutes, parked on a level surface. Pulled out the dipstick, wipe it and insert it back to the bottom and carefully lift it up. I tried so many times and the two sides always look different. I couldn't read it. Maybe I just don't understand how to read it. Could someone help? Thanks a lot!!!
