Amps - no RCA
Ic3Man
Hey guys,
As the title suggests are there any good amps which connect directly to the stock H/U in the corolla without the need of RCA ports ?
Any key words I should try typing into google to find this sort?
I don't need a very powerful one.. just enough to get a 10", 400w peak power, going.
Oh, and also I'm on a tight budget.. so around <$250.
Any help is much appreciated.
Thanks in advance,
David
edit: crap, the sign was the other way around... <_< <$250 its meant to be... -__-;
Edited by Ic3Man
So you wanted an amp that will run the std head unit without using any rca converter?
If that is so, Audison SRX series is the one that I know, it can uses your speaker signal as its signal IN. I think u can get the two channel for that budget.
Oh ok.. then i guess i'll have to go down that path (RCA converter) ... if there aren't any amps that can hook on..
I was browsing around and came around an MTX amp.. which has this "Smart-Engage" thing.. and I think I read that it can be hooked up to a h/u without RCA.. can anyone clarify this ?? I could have misinterpreted it
Christmas sales are on now :D :D so its a great time to buy stuff, hehe
edit: also if an amp has speaker level inputs, does that mean it can run off a h/u without RCA outputs to drive a sub ?
Edited by Ic3Man
      ‘97 Petrol 6 cyl ‘80 Series knocking/rattle below
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
    9. 1
