2003 Camry Sportivo, I can't open the door from the inside!
Hi everyone,
Please help! I can't open the door from the inside of the car. I have to wind down the window and open from the outside. How do I fix it???? :(
Tricia
So you have removed the door trim exposing the inside of the door?
There will be 4 rods going into the locking mechanism, the outside lock, outside handle and same for the inside. There will be 3 or 4 screws on the side of the door for the locking mechanism and then a wiring loom going into the bottom of it for the central locking.
When you pull on the interior handle what is happening? does it move freely or is there a bit of resistance?
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
    9. 1
      Seat change
