F.S NSW Toyota aurion lip spolier & aurion sportivo cluster
sportivo2007
Selling this for a mate
Toyota aurion lip spolier in blue ( genuine )$100
Toyota aurion sportivo cluster with 71760 kms $100 SOLD
Pick up from liverpool area ,
if your interested let me know and will pass his contact details to you .
Edited by sportivo2007
Company in the U.S. make and paint it for you before ahipping to match your factory colour. Once I can confirm that the U.S. Camry boot is the same shape as the aurion I'll pick one up
The spoiler is almost the same colour as my Aurion...
It came off a series two?
How do they go on?
Just double sided tape?
A little off topic...
With the cluster, if you change it, does the odom get stored on the cluster or in the car?
That's a bit confusing. I mean if mine has 40k on it and I put it in yours and yours in mine does your car now have 40k on it?
Edited by 07Prodigy
Hi mate not sure if its the same colour its reef blue ,it was bought from Toyota to replace the series two spoiler
its hold with two bolts from the bottom you will also need a strong double sided tape
if you change it you would have to get Toyota to reprogram for you and set your current kms
Reef blue, I think it's different, mines ice blue.
I dunno if I want to put holes I my boot...
Thanks anyway.
Ok sweet so when I do change it I have to take it to Toyota.
Thanks mate for your help.
      New Vehicle Key Remotes
      Help with Head unit Upgrade ?
    3. 8
      Just had new alternator installed and reverse camera has los
      Part Wanted for 80, 100, 105 Series Landcruiser Spring Cap
      2016 Aurion Sportivo rear speaker removal/replacement
      2016 Aurion Sportivo missing electric blind button
    8. 88
      Aurion 'Pull Left' Issue Explained
    9. 3
      New member
