Whiteline Front Sway Bar for ZZE123
Hey guys
I'm quite confused by whitelines site,
it has a front sway bar for my model, but then says it is excluded?
heres the link http://www.whiteline.com.au/product_detail4.php?part_number=BTF72Z
can anybody tell me whether this will fit an 05 corolla sportivo or know of someone with experience in the matter?
thank you in advanced
Under 'Vehicle Applications' the ZZE122/123 is listed there
If your unsure, i would say give whiteline a call to get confirmation.
Ask them what the part number is, see if it matches what the website has listed?
Edited by Synthetic05
  • 4 weeks later...
I don't think the front sway bar does much (good) for our car since you want to stiffen the rear. Look into Whiteline's 22mm rear sway bar, it's a fair bit chunkier than the stock bar so good gains to be had
  • 3 months later...
I had the Whiteline rear anti-roll bar on my 03 Sportivo and can confirm it's a valuable upgrade and improves handling in terms of higher corner entry speeds and less understeer on both way into and out of corners. Never got around the trying front bar though, so can't help there.
From all accounts, the front sway (anti-roll) bar doesn't do much good for our cars. In fact, some people believe it is detrimental to its performance, i.e. more understeer. The rear sway bar is the best bang for buck mod ever and the best thing is you can use it everyday
Hey Everyone! Got a bog standard 1ZZ-FE and seriously thinking of the rear sway bar upgrade from Whiteline, part number BTR77 (22mm). As we all know, the Rolla is set up for chronic understeer, any chance that this could aid in higher cornering speeds, more neutral handling at the limit, whilst not being twitchy and dangerous? Thoughts from everyone who's got the mod would be really appreciated! Thanks!
