dyno run
Wow only 156kw? I thought aurions are 200kw.
Manufacturers quote power at the flywheel (ie with no transmission or driveline attached). Most performance workshop use chassis dynos, which measure power at the wheels. A 25% drop in power between the flywheel and the wheels is not that unusual (due to losses in the drivetrain).
All dynos are different too. A car will read differently on a Mainline dyno on a hot day compared to a Dyno Dynamics dyno in Shootout Mode on a cold day. Bob's Hot Rod DD dyno will read differently to Pete's Performance DD dyno etc etc
Mate I appreciate the information. I never knew that. Cheers. Now to make sure to get a real 200kw haha.
      For Sale: Toyota AE86
    3. 83
    4. 26
    5. 2
    6. 2
      Head Unit with Apple CarPlay
    7. 3
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
