Diesel turbo how much boost
Hilux 3.0 2015
Boost on the 05-Current models is set at 15psi, which it will JUST hit for a brief moment under full throttle acceleration around 3.5k.
The factory turbo can be somewhat safely wound up to around 21psi when tuned without risking any damage to the turbocharger.
  • 3 years later...
  • 10 months later...
On 7/4/2015 at 12:25 PM, trentmeyer23 said:
Not sure about the 2015 models, but I believe the previous were around 16psi.
I have a question to ask. My dad's got an '09 3.0L. His had problems with the turbocharger lately, its been licking lots of oil from the pipe especially because of the fantastic pick up power from the turbo. I believe so it was pulling at around 16psi too, but he took his charger for service and they repaired the lick problem. Now, the other problem we discovered is that is that the car doesn't have the same pulling power like before, the pulling stops at around 2.7 rpm and the noise of the car is irritating as it goes on to 3000 rpm. I wanted to ask who can help us out to try and bring back the aggressiveness power that it used to have, what do we do, do we adjust the butterfly or...?
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
