Geralim
Hi All,
I can easily add bluetooth phones to my Yaris 2014 yrs but I can not see how to delete those devices. As you can only add 5 altogether this is pretty frustrating. Can anyone tell me how to delete bluetooth devices? thanks..
Have you tried unpairing it on your devices?
Depending on the headunit model, it should be under the Setup menu as Bluetooth. From that you may have an option that says List Phone. You should be able to delete it from there.
  • 4 years later...
  • 3 years later...
Hi I am unable to delete devices from my Toyota Yaris 2014. It has 5 registered number already. Cannot add new. It says delete from register  list and there is no option to delete previously registered numbers. Pl help
I have a Yaris and had a similar issue. I just submitted a similar query to GPT. The response was to go into settings, view paired devices, select the device to remove, and confirm the removal. It helped me; I couldn't find the answer on the internet, but I found it there.
      New Vehicle Key Remotes
      Help with Head unit Upgrade ?
    3. 8
      Just had new alternator installed and reverse camera has los
      Part Wanted for 80, 100, 105 Series Landcruiser Spring Cap
      2016 Aurion Sportivo rear speaker removal/replacement
      2016 Aurion Sportivo missing electric blind button
    8. 88
      Aurion 'Pull Left' Issue Explained
    9. 3
      New member
