Posted (edited)
anyone know of any videos or guides to make it easy
i should add its a 5s-fe motor
Edited by 975s-fe
1) Loosen the throttle cable adjusting nuts(the ones that attach to the throttle body) and disconnect the outer cable from the mounting bracket.
2) Rotate the throttle lever and disconnect the inner cable(via the slot in the cable guide).
3) Disconnect the throttle cable from the support brackets on the firewall.
4) Remove the retaining screws and remove the lower driver's side dash trim.
5) Pull back the rubber boot on the top of the pedal.
6) Disengage the retaining clip and remove the cable from the pedal.
7) Remove the bolts retaining the cable flange to the firewall and withdraw the cable from the engine compartment.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
