2009 COROLLA CIGARETTE LIGHTER SOCKET
I have a 2009 Corolla, and I'm wondering if the cigarette lighter socket is smaller in this model? The reason being, I can't put my Nav Sav connection or phone charger connection in the socket without really trying to push it in, and even then, it will just pop out after a while.
I have no other problems connecting my Nav Sav or phone charger into the cigarette lighter socket of my other car (X Trail) or my 2 work vehicles (Toyota Commuter and Commodore).
I was wondering if they are smaller can you get an adapter? I did try on Spare Parts Retail shop, and he didn't sell them or know of the problem.
Regards
Les
Thanks Concord
Hmmm, I thought they would be standard, but wonder why I can't the Nav Sav or phone charger in the socket? Well, I'll try again, and this time I guess I will try and "force" it in - hope nothing breaks???
Les
Just to make sure I got this post right, I just put my Nav Sav into my X Trail lighter socket - fitted like a glove. Tried the same thing with the Corolla socket, and even using all my force, the same Nav Sav won't go in. I've got a feeling the socket is just not as deep as it should be?
I've finally SOLVED the problem, having tried sticking more adapters into the cigarette lighter without success.
I knew that the actual cigarette lighter itself fitted nicely into the socket, but did it work - no, it didn't. So, I took the lighter out, and got a pair of long nosed pliers, and stuck that into the socket as I thought there may have something at the bottom of the socket which shouldn't be there?
I was correct, it appears to be a safety device that stops the cigarette lighter from being pushed all the way in so it can heat up. Yes, it's a "child's proof" device. So, with the pliers I just pulled out the device (like a plastic button), and now ALL adapters can fit into the cigarette lighter socket, and they work!
So, you were right - the socket is standard, but you have to take the safety device out before you can fit an adapter(or the lighter itself), and use it.
Regards
Les
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
