Hello all,
I have an Aurion Touring 2010. Can anyone kindly tell how to get access to the In tank fuel filter and how to replace it? Thank you.
You need to lift the front of the base of the rear seat to gain access. It takes a fair amount of effort.
As trent said, the fuel tank can be accessed under the rear seat.
The rear seat is just fixed with 3 clips on the front part of the seat so it is not hard to remove it.
However, if you are planning to DIY on the fuel filter, I would not recommend doing it unless you are experienced mechanic.
You need to pay attention to remove the cover plate not to bent  and you are going to deal with flammable liquid (the fuel) once you open the cover.
Above all disconnect the battery and remove any form of ignition source. Also have a fire extinguisher handy.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
