Engine dead
Thinedge
Can someone help
I have a Hilux 2006 auto 4lt v6 The problem is I went to start the car but nothing happened dead as a doornail I have a new battery and all electricals are working fine .
I have tried moving the gear-stick up and down out of park but still nothing ,the cable to the gearbox is fine . It did start once which enabled me to drive it home but since then nothing
Im hopping someone can help .
Thank you Thinedge
If automatic MUST be in Park to start--check switch on gear lever.  susspect worn/broken wire.....  there aere wires for revese lights too, don;t mix them up
Edited by Manxman
I had the RACQ come around the mechanic checked everything then said it was the starter motor .so all is well
Thanks for the comments guys much appreciated.
      Stout Owners
      New Member
    4. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    7. 199
      Advice Please
      A Greenskin
