Hi everyone I have the same problem and am unable to open the files to reprogram the sd card, anyone have an updated/current google drive link?
Thanks so much!
Been getting a **** ton of replies for the files.
My google drive purged due to the recent security updates on drive and the files I no longer have !!!
  • 5 weeks later...
On 7/7/2020 at 9:41 PM, CeeBee said:
Thanks Mate that worked for me as well Toyota Corolla 2015 NSW
Hi
Do u still have these files?Could u send to me a copy? The google drive link not working any more
If anyone could share the SD file on google / other drives online that would be greatly appreciated...Having the same problem after battery replacement...
Hi could anyone please upload the files again as the previously posted google drive link doesnt work, thank you
On 11/14/2021 at 7:20 PM, Stephhhh said:
Hi all, I had luck with these files - hopefully they will work for you too 🙂
Stephhhh - Thank you, thank you, thank you.  The files you provided have worked a treat on my 2012 Yaris' PZQ60-00540 audio system.  I formatted an SD card FAT32 and copied the 4 files onto it. Then with ignition completely off inserted the SD card. Turned engine on, waited 10-20 seconds and to my great surprise and relief, the Toyota screen appeared and everything worked perfectly!!   (Back story:  The audio system has been completely blank and unresponsive for the last two weeks following a regular service at Toyota Camberwell - who after 'checking the unit' decided it was just coincidence that the unit failed at the same time as the service and quoted $1000 for a new unit. $1000! good grief.).  Thanks again, you have made my year.
  • 5 months later...
2013 corolla same issue after battery reset. Thanks all for helping. 24.07.22
Took 20 min all sorted 0 cost. This is the process I used 🙂
1. Delete all files from SD card (did not format SD card as computer accessed SD card O.K)
2. Download 4 files from google drive link
3. Open downloads on computer and copy the four files (best method otherwise tries to look for app to open)
4. Paste 4 files into SD card
5. Install in car - worked first time
Dan
Could please link the file which 4 file paste on sd card please
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
