Hi guys! I'm new to this forum, vans and also dual fuel which my new (second hand van) currently has!
It is a Toyota hiace 1996 with dual fuel. As for engine model and other specifications I am not sure (I pick up the van this Sunday as it is currently getting a roadworthy).
However my last few cars I have always serviced myself unless there was a problem that I couldn't fix myself then I would have it checked out. But I have NEVER serviced a dual fuel vehicle or a van.
My questions are, Basically what would give me a really good idea with servicing this is what would YOU do/change/check if you were servicing a dual fuel vehicle? (And if you say "change oil", if you could please tell me what kind (may be different because of lpg :/ ))
And also is there anything on vans that I would need to lookout for? Anything that wears out more than cars? I have heard something about the radiator needing to be maintained VERY well more so in vans but not sure how true this is...
Thanks guys! Any help would be appreciated!
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
