Hilux won’t rev
Pissy pants
Hi guys I’m new to the site , just seeking some help on my Hilux I’ll give a quick rundown on what happens
2006 2.7 2trfe engine
just fitted second hand engine 95,000ks from a wrecker
got it going and runs fine but wouldn’t rev and dieing ,
the exhaust was blocked , cleared it from the broken cat
it now goes okay but it still isnt Normal and lacking it power , it barely hits limiter and sounds like it’s pinging when doing it , also struggles to do 80-100ks when the old motor screamed lol
ive had a bit of a tinker and fuel filter seems clean , plugs are okay , coils look new , I’m wondering if the exhaust could still be blocked or something or o2 sensor
but i wouldn’t of thought so , any ideas or suggestions would be good
runs and drives but a 1.5 excel would kill it it just isn’t right cheers
Its obviously not running the way it should, How in gods name is revving the sh*t out of it gunna make it run right.
It sounds like the timing is way out,
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
      Rav4 smart key keyless entry
    9. 13
      Starter motor issues
