Rear Window screen
Internet search located the following Toyota Aurion brochure pdf with a print date of May 2014.
https://www.toyota.com.au/static/vehicles/aurion/content/pdf/aurion_saver.pdf
Aurion Sportivo ZR6 has the electric rear sunshade as standard equipment not the Aurion Sportivo SX6.
Details should be in the owner's manual, if you have one.
Maybe following quote from a BMW Forum is applicable: "" Look at the controls on the driver's door. It should be right under the window controls.""
    2. 83
    3. 26
    4. 2
    5. 2
      Head Unit with Apple CarPlay
    6. 3
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
    10. 1
