New member with new question
Meltale
Hi there, I just purchased a 2015 Kluger GXL. Today I found that it front left fog light fallen off. After a quick investigation, I found it had been damaged before and glued back to the bumper. It is from a dealer, however, as a secondhand car I don’t think I can claim a repair from them , can I? If I am going to fix it by myself, what is the proper name for the holding bracket of the fog lamp, does anyone know? Thank you very much.
Hi Haibin and welcome to the forum.
I would certainly approach the car yard you purchased the car from..they can only say no....sorry not our problem..which they probably will say being a 2nd hand car dealer
but it is worth a try..let us know the outcome.....others on here may have the answer to the bracket/fitting required to fix the light in place..
Good Luck
KAA
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
