Wanting some knowledge for EPB (Electronic Park Brake) removal and disassembly. I wanted to paint rear calipers and wanting to completely remove rear calipers for better paint results. Im aware of putting it on Neutral, put on acc then put park then turn off car completely to disengage EPB. However im not really confident on using this way. Anyone who have done EPB removal before im kindly asking for some advice and knowledge. Thanks!
Accessories on, push the park brake switch down for 5 seconds while your foot is on the brake then take your foot off while still holding down the switch for another 5 seconds then release. It should move the EPB all the way back, this also allows you to push the piston back when doing your own brakes.
Well it should work as that's the trick on any Lexus with an EPB.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
