Hi, does anyone know where the secondary air pump is located in a 2005 Hiace? I've been looking but still haven't found it. Thanks people.
Have you had a look in your owner's manual ? I'd tend to think that it should have some kind of reference to it there.
Google search yields almost nothing either, but I suspect that such a pump would be in a similar position for other diesels, in which stated "The pump lies after the exhaust manifold and before the catalytic converter"
Take a look under there, I'm sure you'll find it.
Good luck and if you do find it perhaps post up some pics so others can benefit from this post
Cheers mate :thumbsup:
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
