Hybrid model rear 150 v power adaptor
Steven barbaro
16253723750594487926205003819612.thumb.jpg.f2b4ba39e7a439eff07587e47e4bf930.jpgHas anyone found a useful adaptor to use in the mains 1500 w16253723750594487926205003819612.thumb.jpg.f2b4ba39e7a439eff07587e47e4bf930.jpg adaptor , apparently it's used for hair dryers , fridges etc in earthquake situation when they live out their vehicles in emergencies
Japan uses the same NEMA 1 socket/plug as the USA does, 150V seems a bit high for Japan though (their domestic supply is 100-120V).
3 hours ago, Steven barbaro said:
I meant 1500w , that's what is printed on the flip open cover , I'm not sure what that is in volts
Really depends on whether it is DC (battery voltage) or inverted AC.  If it is truly meant to be an emergency mains supply in Japan then it would have to be 100V inverted AC, which would then correspond to 15A (which is still a sizeable amount of current).  I think Toyota's hybrid batteries tend to be around 250V which would mean only 6A, but 250V DC will fry just about anything you would normally plug in to a DC source (normal cars are only 12V).
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
