Hello fellow GR enthusiasts,
I have the following Paint Protection Film (PPF) cut to size to cover the front and rear badges. This is a good measure to protect your badges from the inevitable stone chips and scratches. These PPF films are of high quality and are self-healing when exposed to the heat.
The following is included:
·         PPF cut to size for front badge
·         PPF cut to size for rear badge
As per installation, it is fairly simple for a DIY job. Instructions will be sent after purchase.
$10 for the two posted Australia wide.
10 available.
I'm a huge proponent of PPF as my biggest bug bear is stone chips, especially on the front end. If it were me, I'd do the whole nose section up to the leading edge of the bonnet. That's where all the carnage will be. When the PPF gets tired after a few years, you can always have it redone.
It's cheaper than having the front end resprayed too.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
