Posted (edited)
I'm after advice on where I can get a set of wider, longer front mud flaps for my 2019 Hilux SR. It has a motorhome fitted to the chassis and I want to prevent stone chips by fitting wider, longer, front mud flaps, prefereably using the existing holes, but happy to drill new holes if necessary.
Edited by Billy W L
just a thought what about rally car mud flaps 500mmx300mm 3mm thick cut to suit about £30.00 british pounds on ebay
Thanks. I've been looking at ones similar size to that to cut to the right shape. Plenty available.
i know eek    landrover defender mudflaps 292mmx385mm roughly shaped  cut and use heat gun to fit not that dear on ebay can get without logo
Try looking at trucking supply stores. They usually have several different sizes (portrait & landscape) available and are made of material that is easy to trim to size.
Thanks all. I just bought a pair of 17" x 15" mud flaps from ebay. I'll cut them to size and see how they go.
Id go to the likes of Clark Rubber theyll have a range of what youll need
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
