Hi all. I have a toyota aurion 2007 atx
recently i was seeing miss-fire from the exhaust and the engine was heating up .
so i checked the reservoir and radioator both of them bone dry .
went to the mechanic they did pressure testing there was no leak and so they think that it is head gasket failure .
i have filled the reservoir but it becomes bone dry after a while.
Hi Abu,
Before you rip the head off, check your radiator cap. I had the same issue and a new cap solved it.
Herb
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
