Driver's seat base leg support.
Just picked up a 2015 Ascent Sport and this is my first post. did a return trip Brisbane to Tweed heads and very pleased with it. I have one issue that I would like to correct if possible. I find that the front edge of the driver's seat is too low and provides no support at all under my legs just above the knees. I am looking at trying to elevate the front of the seat base if possible. Any suggestions welcome. -
Head light Relay Location corolla 2005 wagon Japan ver. 4AT
Hi guys, I was so many diagrams but my car is different. The head light Relay spot is empty in my car. Can anyone help me to find the relay actual location? When switch the head light on, I can hear click sound under the steering wheel but I can't see any relay there. -
1992 1hdt both blinkers flashing together
Hi Tony, I don’t think so. When operating the hazard switch the dash lights are quite bright. When I turn either blinker on they are not as bright. I think it is an earth issue, maybe in the blinker switch. I’ll pull it out tomorrow and clean it with contact spray unless someone has a better idea 😁 -
Problem with the hazard warning light switch? -
Rear speakers?
On my dual cab SR rear speaker wires and Plug were already in place, I just got a couple out of a SR5 from the wreckers, perfect, Get yourself or make a Memory saver, ( 9v smoke alarm battery, 2 alligator clips, and the plug and 2 wires from Jaycar ) worth every cent and saves resetting everything if battery is needed to be disconnected Safety 9V Battery Clip - Highest Quality | Jaycar Electronics -
Centre Bearing Replacement
Check if there is a Front Arrow and the centre bearing is actually running in a straight Plane, what are the uni's like, For you to experience Shuddering, its pointing to a Flogged out Uni. Don't know about the smell of burning rubber, if you greased the uni,s might be just grease on the exhaust. Put it in gear 1st, hand brake off and get someone to rock the vehicle back and forth and get under it and visually look and feel each and every uni and also the slip joint near the centre bearing for excessive play -
RAV4 19" wheels on Aurion
Wheels arrived today & I had time to sand one of them with a SIA green superfine pad (600-800g) Much better already 👍 Regarding tyres, I've purchased a set of Nexen N'fera Su1 in 235/40r19 for $220 fitted which is pretty good for a mid range tyre -
I have changed the flasher can, not the problem. Wondering if it could be the multi function control stalk? -
