trd vs whiteline swaybars
WYTNYT
as far as I'm aware, neither of them are hollow.
standard rear swaybar is 18mm
TRD is 23mm
Whiteline is 22mm
I'm not sure on the specs of the fronts off the top of my head though
another option is C-One also but they are more expensive than TRD
not for a ZZE model Corolla... the rear suspension setup does not really allow for it.
Whiteline do adjustable fronts, but not rears.
there are adjustable rear swaybars for previous models with Independant Rear Suspension.
I got all whilteline gear.
I put the spring in and it handled well
I put the the rear sway in and handled better
I but the front strut brace it handled much better
I put the front sway bar in and it handled so much fn better and got rid of my axletramp problems.
So i'd go for the whole package in whiteline. It looks like they design each component to work toghether. I am a very satisfied customer.
whats the cost of the front and rear sways either whitline or TRD?
sounds like a useful mod
TRD do not make a front sway bar, however C-One does(roughly looking at $400+). TRD rear sway bar should cost between $250 - $300. Install on rear sway bar shouldnt cost much at all; it will take a workshop no more than 10 - 15 mintues, alternatively you could do it yourself.
Edited by ar44
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
      High mileage camry
