1st to 2nd
Everyone who has modded there car with Quick Shifter (i assume that is in relation to changing gears lol) has it had any effect on changing from 1st to 2nd at 8k? Cause my car makes a rough crunch noise when i change from 1st to 2nd in that rev range.
Or would i have to change the clutch and flywheel and if anyone has done it, how much did they pay ?
the parts are about 1200 and labour is around 600.
hoep i'm not jinxing myself here but since i got the bits, i haven't experienced that sticking and crunching. apart from when its cold i still sorta feel that i'm brushing past something metallic when shifting. but its all only in the first 5mins when all is warming up
with my experience.
I was told that if your gear selector cables are tight, you will get some of this feedback
With my custom headers on i had to raise my gear selector cables above the headers.
Thus making them tighter, so the gear changes need more effort to slip in.
Could this be the problem for you sportivo people?
i get the same crunching and grinding feeling when changing gears from 1-->2-->3
i haven't told my dealer about any of my problems though.
i'll tell them when i get back from Darwin
with my experience.
The dealer put cable ties in my Stivo to lift one of the selctor cables away from the exhaust heat shield and the other cable. It solved the rattle for about 6000kms but i recently heard some rattles during shifting at high revs. I also suspect the cable ties might have caused the "Sticky/Locking-up" shifting feel.
Another great possibility is the tranny oil or gearbox lube. It probably needs something of lower viscosity or better quality.
Zee
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    6. 4
      2013 camry for sale
      Rav4 smart key keyless entry
