Posted (edited)
Hey all, i am trying to figure out my tyre pressure, last time i did it, i put roughly 32 psi, but it did not look like enough, what do most ppl put in theres?
NOTE. SORRY I CLICKED WRONG SECTION PLEASE MOD MOVE TO WHEELS & TYRES
Edited by SPTIVO_LUVA
how are you measuring it?
If you are trusting the digital readout from the servo self inflater... forget it... invest in a spring dial pressure gauge (~$8 from any auto shop) and test the pressure after it's inflated, you will find it wavers around some times.
as blue_stivo said invest in a gauge
and make sure u measure the pressure when the tyre is cold
if u have driven down to the servo your tire would have gained preassure and PSI will be higher !
i thought the digital ones which beep at the set point were good. i know the analog ones which ding at the set point were not accurate since the handle which contains the gauge was always dropped. i heard that if you need to drive to the servo to get to one within 8 km of cold tyres or they heat up too much.
BP servos usually have a tyre inflator with digital reading that beeps (as kcorro indicated in previous post) and/or blinks when the desired pressure's been reached.
a few things that i would always keep in mind to keep the tyres from heating up too much on the way to the servo:
1. drive to a servo within 1 mile (1.6 km) of cold tyres
2. don't drive faster than 40kmh and try to minimise the stop n go
3. the colder the weather, the better
4. redo the tyres at least once in case it didn't "sense" the tyre pressure correctly the first time
    2. 1
      Tyre Sale Specials
    3. 0
      overheated engine
    4. 1
    5. 62
    6. 1
    7. 1
    8. 1
      Tyre Sale Specials
    9. 10
      Android auto
    10. 0
